HI,
I wrote the image to the sd card, then i added my credentials to the wpa conf file. I then booted the pi and tried connecting to link :
openscanpi:1880/ui
but it wont connect.
I then connected to ssh@pi using the ip of the rpi and i connected to the terminal. So the wifi is working but it wont connect to the ui
any way of checking whats going wrong?
thanks
you may have to use the actual IP address with :1880 to get it to connect
