When I export the zip file Windows reports not being able to open it. This error:
7-zip can open it but does report a problem with the file ending. It looks like it was broken off. Also, only part of the photographs are found in the ZIP file. In this case it only contains 49 of 200 photographs.
Has anybody else encountered this problem? And does anybody know how I can directly access the store of photographs?
I'm using the PI version of openscan and have tested this with a raspberry Pi 2 B and 3B. Both on Openscan PI 2020-01-26 and 2020-02-04
This error should be fixed with the latest update (2020-02-04). Before this update, the zip file was already shown in the filelist before it was ready. I can recommend 7zip (freeware), as this can also open corrupted files.
You can also access the pi's filesystem directly by switching samba on (which should be on by default) and adding the network drive in your PCs file explorer. Just add \\YOUR IP\pi as new network-address.
Hello thomas, thanks for the quick reply. I tried 2020-02-04 last night with the same results. But I'm not sure if the update was installed correctly. See my question in the updates section "Update 20.20.4 - strange camera window". I'm doing a couple of tests now and will also check through Samba. Will report back later if I have more results.
I just reinstalled version 2020-02-04 and now it all works. Also the problem with the screen seems to have dissapeared. Thanks again.
That's great to hear! The problem with the screen only appears on first start. It might happen again, when you use a different computer to log in (but now you know the solution :)
