I just got the openscan raspberry pi up and running. I can scan the image but when i go to download the files it gives me the error Cannot GET /ui/data/zip/2021-03-27_22.11.53-cap? Anyone know how to fix this issue
Joshua, I'm having problems finding the Raspberry Pi on my network. Any advice? Wish I could help you with your problem. By the time I get to where you are I should be totally lost. Jeff
I name the scan after I have downloaded it.
For anybody having the same problem: The solution is to not use spaces when naming your scan
Unzip the file??
Hi, have you found a solution to the download problem yet? I also can't get my files to download…
https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md check this site out. Make sure your wpa sipplicant file is correct and make sure you can see it on your network.
